Why is my Hewlett Packard Photosmart 7520 wireless color printer slow in print documents? I recently bought the Hewlett Packard Photosmart 7520 wireless color printer and getting it to print quickly is becoming elusive. I have speed up the printer by reducing the printing quality yet the printer is still very slow. What are other options to speed up the printer?
You may want to try this simple, free, except for the time and effort. At the back of the Router, unplug the optic cable and switch off the router, un-plug power cord from the router. While the optic cable is unplug from the router, plug the power supply to the router and switch on the router. Reboot the printer and try printing.
If you have the HP Photosmart 7520 e-All-in-One printer and you are printing wirelessly, check that the printer is placed not too far from your computer. The distance between the two devices affects the speed of the data transfer which in turn is reflected on the speed of the printing.
HP Photosmart 7520 e All-in-One Printer
If you experience slowness in wireless printing, try moving the printer closer to your computer or your computer closer to the printer. This should improve the printing speed. Also, try updating the driver for your printer. Go to HP Photosmart 7520 e-All-in-One Printer to get the latest driver. Here, select your correct operating system.
If the page detected the wrong platform, click “Change” then select your correct operating system. Download and install all available software for your printer. An updated version of the driver is available for download to support Microsoft Windows 10.
1....
