Why my Internet connection is so slow?
Hi guys, I use Beam connection which is a cable one since I started using it the connection is slow only except sometimes when its speed is increased but very rare when I contacted their customer support they say the connection does not have any problem and unplug and re plug the cable that will work.What shall I do now please help
Answered By points N/A #188786
Internet speed is a great fact to the users when it is quite urgent. Increasing internet speed requires faster connection of your internet package so check with your ISP to upgrade to faster package.
Sometimes, faster connections also fail to satisfy one’s mind. In such case, you have to do some tweaking in your system that will definitely give a good result.
1. From “RUN”, type “gpedit.msc” >> hit Enter.
2. Go to Computer Configuration >> Administrative Templates >> Network >> QoS Packet Scheduler >> Limit reservable bandwidth.
3. From the top-left corner, select “Enabled”.
4. From the “Optoins” box, change the percentage of “Bandwidth limit (%)” to “0”.
5. Press Apply >> OK.
Also, use any good browser, e.g. Google Chrome, Mozilla Firefox, Opera etc. If you already have, clear their browsing history by clicking “Ctrl + Shift + Del” on any browser.
Hope your connection is fast enough to satisfy your mind.
