Why my internet explorer showing error message?
My internet explorer sometime shows me error message. The error tells "Problems with this web page might prevent it from being displayed properly or functioning properly. In the future you can display this message by double clicking the warning icon displayed in the status bar.
What should I do to get rid of this error?
Answered By 0 points N/A #82505
Your Internet explorer showing this error because the page you want to display or access is having some problem that's why your internet is explorer is displaying this error. if you want to display the error click on the warning the code error will be displayed. check for the code error what it is. This kind of code or error appear due to the Java script which is stuck.
If you have disable your java script from your internet explorer security setting then what you have to do is to enable you java script and make your internet explorer working properly. These are common error to many people. Hope this will solve your problem and thanks for asking in techyv.com.
Thanks
