Why my Laptop not connecting to Wi-Fi?
I use HP laptop and it used to connect to wifi automatically until now I tried every bit possible to connect to wifi but it's not
working. I even made my home network to connect automatically going to manage wireless connection and deleted my
existing connection but still my Laptop cannot connect to Wifi automatically.
Best Answer by Edmund Joseph
Answered By 0 points N/A #118376
Laptop automatically connect to WiFi when its infrastructure mode is in ''Access Point". If your computer previously connect to WiFi automatically, then it can be said that your wifi mode is in "Access Point". For connecting to that WiFi automatically in Windows7 you need to go "network & security center", click "manage wireless network" on left side. Then remove your existing wireless network. After that restart your computer & connect to your desire WiFi connection. Make sure that there is an ok sign on "connect automatically" option while you are connecting to your WiFi connection.
Answered By 5 points N/A #118377
Hi there user:
No need for you to panic. First, check your WIFI router if it’s working properly (signal). Now from your laptop, check your access to the WIFI. The problems could be in your unit, or in the router. If the problem is in the router, it could be the signal or was reset.
Click the signal icon on your laptop and connect to the wireless connection (WIFI). Right click the wireless connection and then select Properties. Then manually type the username and the password.
It should connect to your WIFI this time around.
Thank you for posting questions here at techyv.com.
Best regards,
