Some issues are arising with my MadCap Flare. Windows 7 has flare in it and I use it.
The MadCap Flare is creating troubles while performing. Its functioning is non-consistent; few times it works and the other times it crashes. The only solution I could come up with is to uninstall and then re install flare because I cannot find the cause of the difficulty.
Kindly lend me a hand in knowing that either windows 7, or hardware or flare is creating the problem.
Why is my MadCap Flare inconsistent in performance?
Initially make sure that you are enlaced with the following:
• Supported Operating Systems: Windows XP Service Pack 2 or later, Windows Vista, and Windows Server 2003, Windows 7 (32 and 64 bit).
• Required Software:
Microsoft .NET Framework 3.5 SP1 or later
Microsoft SQL Compact Edition (Installed on a first use run of Flare)
• Pentium 4 or higher processor with at least 1024MB of RAM and 420MB of available hard drive space.
• Microsoft Internet Explorer 7.0 or later
• Adobe Acrobat Reader
• Java Runtime Environment (JRE) 6.0.15 or later (for Adobe AIR compiling and for use of the equation editor)
• Optional Microsoft Word 2003 or greater with the latest service pack (for Word Output)
• Optional Microsoft Outlook 2003 or greater (32bit only) for sending review packages
• Optional Adobe FrameMaker version 7.0 or greater with Distiller (for FrameMaker Output and PDFs from FrameMaker Output)
• Optional for viewing Adobe AIR Outputs: Adobe AIR Runtime
• Optional for Version Control: Microsoft Visual SourceSafe 2005, Team Foundation Server 2005, 2008 or 2010, Subversion 1.5.3 or later
• Optional for use of the equation editor and for generating PDFs with equations: Design Science Ghostscript
• Supported Web Browsers for Web Help Output: Internet Explorer 7.0 or later, Firefox 3.5 or later, Safari 4.0 or later, Google Chrome
After you are convinced and positive of the presence of above mentioned requirements, then re-install the software. After the installation you better make use of a registry cleaner to clean up any extra or attached flare to Windows 7.
If the issue is still unresolved, the trouble is with your Windows, uninstall and then re-install it, and then install the flare again.
