jdsky
Posted on - 09/21/2011
I have a mobile. It's looking nice. It has support multimedia. Battery support is ok. But this mobile now and then not charging.
I checked all input-output jack, no problem has found. I changed a new battery. But  result is same.
I also checked by  specialist, they are comment everything is ok. But why I facing this problem ? Please guided me.
Look at my mobile…
Why my mobile have shown abnormal behavior ?
If your cell phone is not charging, it means one of two things:
1. There is a short fuse in your charger and it has gone bad.
2. (Most Likely) The charging port (the place on your phone you plug the charger in) has become loose.
Unfortunately, neither of those things you can personally fix, but, both problems can be fixed.
Recommendation 1: If you know someone who uses the same wall charger as your phone, barrow it and test it on your phone, If that works, then you know the problem is with your wall charger. If it doesn't work, then the problem is with your cell phone.
Recommendation 2: If your phone is within the one year warranty period, you can contact your cell phone company and place a warranty claim for your cell phone. They will send you a refurbished phone at no charge. You will need to send your broken phone back within 5-7 days to avoid being charged for it. If your phone is not sim based, you should go to your local retail store to get assistance with backing up your phone numbers.
