Why my PC is not detecting graphics card?
Hi guys, I want yo know that why my PC is not detecting graphics card.I don’t know how all this stuff is done but to have a good quality screen and playing experience I buyed Nvidia graphics card I don’t even know what is its number and all that as I purchased it from my friend and then tried to insert the card but my PC is not d
etecting it please help me solve this. Thanks
Best Answer by Riley Keith
Answered By 0 points N/A #182232
Louie,
If the card is well connected, the fan in it should be spinning.
Maybe the problem is that the video control is not in automatic at the BIOS and you  need to configure it.
You have to go to the BIOS, restart the computer, depending on the brand or model, maybe you need to press ESC key, or F2 key, or DEL key. When your computer starts look the message and there is one that maybe says press "" key to enter in the BIOS.
Once in BIOS you should go to the hardware part and check the one related to the video slots or adapter. Enable the slot or set it up on automatic. Save the BIOS configuration and restart.
If the new video card driver is well installed, now you must have it running fine.
Riley
Answered By 0 points N/A #182233
You did not mention about your system. If it is Asus, the most recent version will work.
  • In the BIOS setup, make sure you configure the card for using the PCIe slot as graphics.
  • Go to the device manager and disable the previous graphics card and following the same steps enable Nvidia graphics card.
Answered By 10 points N/A #182234
Hi, there might be some problem with the graphics card if its new please check that your card is correctly inserted and if it does than remove it one more time and again insert it but before doing so check for the dust there should not be dust in the card slot and the card should also be dust free then chack if the PC detects your card or not.In most situations this will work if even this does not work then let a PC repairs person look for the problem.
