Hi guys I have windows computer which works on vista and while purchasing this computer I purchased speakers also but these speakers when connected to other media devices works well and not at all working with my PC what might be the problem do anyone here know I even checked they are connected correctly in all the ports or not but still they are not working please help me solve this.
Why my PC speakers are not working?help
You will build your solution following these;
Go to the ‘Control Panel’ of your computer. Â
Click on the ‘Sounds and Audio devices’.
Go to ‘Audio tab’.
Using the ‘Sound playback part’ and selecting the ‘default service’ you may introduce your speaker to the computer.
It is under ‘Advanced’ button.
Press ‘Speaker’ tab.
Pick your speaker all the way through ‘Speaker Setup’ button.
Hello, This is not a big problem don’t worry just unplug your speakers and re plug it again and check it is plugged correctly then go to the control panel and click on audio settings then check for your available devices and see if it shows the speakers is connected if not then if your speakers is wireless one then click on add wireless device and let the PC detect speakers.
