I cannot understand why ssl vpn Mac stops working suddenly after updating software. I updated the software last week and it’s not working now. Why it happened and what is the solution? Please help me.
Why my ssl vpn Mac stops working after update?
In order to access the SSL VPN, you will need to download VPN client on the internet. It uses a Java based client installer That will let the users to connect from your PC browser. Try to check if your Java is already updated. Since you did not mention what version of SSL VPN update did you install, I am not sure if you need to roll back or update your Java. To roll back Java, just uninstall it and then download the version before your current version and install it. To update it, just go to the Java home page and download the recent version.
