Burak Erdem
Posted on - 09/27/2011
I'm using Tab PC – 8" mid tab pc with Android 2.1 OS Built in Wi-Fi, 3G.
Rockchip2818 Processor, Integrated Graphics Card, multi-point pure touch screen, Love Phoenix Brand, 8" high-definition LED screen, Rockchip Processor Brand, 256MB Memory Capacity, 700MHz Frequency, 800*400 Resolution. Recently I am facing touch screen problem. When I touch any file or folder it not work. I need to touch 3 – 4 time.
Can you please tell me what happen here & how can I solve it?
I check my all setting everything is okay then why I facing this problem?
Thank You
Why my Tab PC touch screen not working?
Based on your observations, the problem is on your screen's sensitivity or calibration. The fact that the Tab PC did respond to your 'touch' after 3-4 times means it is working. It is just not sensitive enough to detect your 'touch'.
Please try out the following solutions, and see if any of these will work for you.
(1) Re-Calibrate your touch screen settings.
1.1 To do this, go to your SETTINGS menu, and select CALIBRATE
1.2 Follow instructions for calibration. Make sure to complete the calibration process.
1.3 Save your settings
(2) Based on several reviews on the common issues encountered for Tablet PC, try using a stylus and see if it is more responsive than using your fingers.
Good luck.
