Hi guys, I use acer laptop with windows 7 in it and it is showing this message whenever I’m opening it that “your browser preferences has been changed and click yes if you want to keep it and no if you want to set the default settings again” this is the message I get every time when I open my PC.I don’t know why it shows this message please help me solve this.Thanks in advance
Why my windows show your browsers preferences has changed message?
Hello, this is the problem that your browser wants to make changes but you did not approve them so the PC is showing the message every time that you have un saved changes. Firstly go to your browser settings and open search engine settings there you will see the list of search engines from them keep only which you want to use and remove other search engines and select the default search engine. This might work if not then un install the browser you are using and download it again.
