Hi guys,
I want to solve this problem as soon as possible because I use internet via WiFi router tht is only WiFi connection to browse internet but suddenly my PC fails to detect any WiFi networks why? I never had this problem before but its really bad for me unable to work and this problem is since two days please help me solve it.
Why PC WiFi network configuration fails?
Hi Edward, if your computer cannot detect the WiFi network, if you have another device try to check if that can detect the network. If so, then the computer maybe is the issue. Try these simple basic steps starting with distance. Have you changed the location of the router or your computer? Another factor is since wireless connection for the router also uses the same frequency as your microwave ovens or wireless phones, this might be causing the interference. If there are too many connected also will cause a likely bottleneck with the signal. You can also disable first your firewall as well as the anti-virus on your computer. Then re-connect and re-boot your computer. If it's connecting your firewall or anti-virus might be the cause. Don't forget to activate both anti-virus and firewalls for your computer's safety.
