jeff mathie
30 points
Posted on - 08/19/2012
When I was using Pdf2txt ORC I came across this error and the application has stopper working.
Can someone say, why this has happened?
And how to fix this?
Pdf2xtocr.dll
Pdf2xtocr.dll has stopped working A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Why pdf2txtocr.dll has stopped working?
First of all turn off for DEP for "pdf2txtocr.dll" to try again. Please follow the instruction given below to start off DEP in your system:
Click Start and select Control Panel
In the Control Panel select System and click the Advanced tab
From the Performance area select Settings and click the Data Execute tab in the dialog box and open it.
Select "Turn of DEP for all programs and services except for those I select" and click Add.
A dialog box will open. Browse and select 'pdf2txtocr.dll' application in your computer.
Click Open and go to Apply.
Last of all click OK and reboot the system.
I think your problem will be solved.
Hathy
