Why problem occurred after update on flash activex sound?
I was enjoying my flash player well and I got a notification an update of adobe flash player active x is available. So I have updated and getting problem about flash activex sound. What is the solution?
Answered By 30 points N/A #181804
Sometimes the software makes much problem when we update it.
The notification tells us that the new version or update of the software is available, but when we download and install it.
Then it becomes the reason of many problems. Because the software cannot support the new downloaded files as updates.
You are facing the same problem.
Please uninstall this update that you have done recently.
You should never update this software. When you find that new version is available then remove old version and download install the new version.
I hope you will able to make changes as I said to remove your problem.
Thanks
