alex baker
30 points
Posted on - 11/17/2012
I have installed realplayer recently and after installing realplayer distortion in audio output occurs. The actual sound is distorted somewhat while playing both audio and video files.
No problem with other players.
How can i correct this problem.
What might be the possible reason?
Why realplayer distortion in sound occurring?
It is recommended that you should use the current version of Real player to guarantee the best audio and video streaming.
The latest version of RealPlayer12 is free and is available for mac OS and Windows.
You can download it from this link
http://www.real.com/
I hope it will solve your problem for audio and video streaming.
Regards
The majority of sound distortion issue can be resolved by making sure that Realplayer's settings are set accordingly with your computer's hardware.
If you are facing these poor playback quality while streaming content.
Make sure that your sound card have no conflicts with other device.
Play other files to check.
You should update your sound card driver.
Try to do these all steps i hope you will not experience this problem again.
