Recently I'm facing some problem after update bios using Intel integrator assistant. The error showing missing but it update auto then how it showing that type of error? I need your help.
Why showing error Intel integrator assistant after auto update the bios? How can I solve it?
Kerk P
10 points
Why showing error Intel integrator assistant after auto update?
Hi Daniel Moraes,
About your problem. You better do nothing. if the performance of your computer is fine. It means do not updates the bios if the performance of your computer is fine. Just Update the drivers of your computer example ( Media Graphic Adapter Driver, multimedia driver, Ethernet Adapter) You better Reset your bios. Restore it to it's default settings. Read the Motherboard manual and follow the steps on the Motherboard manual. If the problem persist? You better consult the manufacturer of the motherboard of your computer. Or else Try to update your windows and let the windows update download and install the drivers that your computer need.
Hope my idea could fixed your problem.
Good luck!
