Hi to everyone. As portable document format is considered the best way to exchange documents over the web but it has also disadvantages. Sometimes it becomes difficult to edit and copy data and changes can not do with it. I also tried to copy some pdf images extract to ppt file but whenever I open file after saving, the images disappear automatically. I wonder why this happens as everything is saved on hard. Any help please.
Why some PDF images extract are not showing in another file?
There are no disadvantages once you have the right PDF editor from which in your issue that might be resolve. For all over 5 years of using this PDF editor and export it as pdf, it is then you find the result what you need. I recommend you to check this site for your issue, it is very lightweight and very handy:
https://www.foxitsoftware.com/pdf-editor/
Other ways around if you don't want to purchase, I use PDFCreator which is free of charge.
https://sourceforge.net/projects/pdfcreator/
Download and install in your machine, once it is installed, on your Word Document, Go to File then Print, select print to PDF Creator.
Hello.
The PDF format was invented by Adobe systems as a means for people to distribute documents between one another and across different platforms such as Mac and PC. Adobe eventually released the software as an open standard and now anybody can create there own versions of PDF's.
This sometimes leads to problems like you are currently having with one program not always reading a PDF that was created in another program correctly.
A good program to edit PDF's is NitroPff. It can re-save your PDF into a PDF format that is more compatible across more platforms and different software packages.
