Why SQL Server Express is not installed with visual studio 11
During the installation of Visual Studio 11, why SQL Server Express is not installed together?
One or more Web Application projects in this solution require SQL Server Express. You will need to download and install the appropriate version of SQL Server Express for these projects to work.
OK
Best Answer by Ratyr patsr
Answered By 0 points N/A #138770
SQL Server Express is need for Visual Studio 11. You need to get a disk containing SQL server Express. Install it. then you need to install the actual Visual studio software. You may try buying a premium version of visual studio and SQL server express.
The software work fine and is a very good technology to rely upon. You may install at trial pack, however some features are disabled. Some manipulated versions are also available in some sites.
Try downloading them. Your purpose, if for a student or for some small software building will be solved. Naturally, you need to first install SQL server express.
Answered By 0 points N/A #138771
Since, Visual Studio 11 do not include SQL Server Express pack with its installation pack. So, You have to install SQL Server Express pack individually before installing Visual Studio 11. You can download use below links to download SQL Server Data Tools for Visual Studio 2012:
After downloading SQL Server Data Tool you can start installing Visual Studio 11 again then it won't give any error.
