Why Sunix the ultimate docking station?
I am looking for  docking station and found Sunix. Will anybody help me why they consider this the ultimate docking station from the others?
Sunix is the best-rated as an ultimate Thunderbolt docking station . This appealing and outstanding dock feature with a Gigabit LAN port, four USB 3.0 ports and a Multiformat card reader which supports MMC, an xD media, SD, MS and a stereo sound playback by using SPDIF digital audio interface. The vendor has also attached a slim Blu-ray writer and 3.5 inch single-bay SATA 6Gbps HDD. The HDD bay holds hot-swapping and the driver  can be simply removed  from the dock.
Having two Thunderbolt ports allows multiple devices to be wired together in a sequence, for example the external display. It is very convenient to be used for devices which has minimal numbers of connectors and ports such as the Macbook Air or any other future Ultrabooks.Â
