Why is thumbs.db file created?
I am using windows XP and whenever I create a folder and keep pictures in it, I found a thumbs.db file automatically created
within that folder.Does anybody know why this file is created?
Best Answer by
Answered By 5 points N/A #118381
Thumbs.db is a file that is automatically generated cache of thumbnail and it is preferred to completely delete it as it is safe to keep away by deleting immediately.
The thumbnails are the tiny version of images in which they are displayed in some folder views and it cannot be seen in windows explorer as it will be in form of hiding in folder.
It is normally an hidden file and drag it to visible state by changing the view settings from the folder options by clicking on radio button show hidden files and folders.
It is not easy to delete all the files present in the system and for now the only way is to delete them but next there is an option to stop creating thumbs.db files by checking Do not cache thumbnails.
Thank You.
Answered By 50 points N/A #118382
Thank you so much to the expert for the solution. I had been driven mad by deleting all those thumbs files and they keep coming back! I didn’t know there was an option to prevent it from creating thumbs. Thank you so much, a very useful tip you have provided
Answered By 0 points N/A #195318
Hello Dear,
Thanks for sharing your problem with us.
Dear thumbs.db is a database file which contains the information about thumbnails of any video or picture.
You see that any picture file or video files is shown just like a picture as below.
This picture is thumbnail view of icon.
I hope it will help you to understand your question.
Thanks
Answered By 0 points N/A #195321
Dear,
This is a database file. It is created for any folders that contain picture files or media files in thumbnail mode. This file saves information about the thumbnails. This file will not create any problems, so you do not need to worry about it. If you want to remove this file, click on "view" and remove the tick from thumbnail option. Now, you are free from this file. Thanks.
