Why we need to use pic compiler? I would like to know the main purpose and the advantage of using a pic compiler and how does it affects your coding efficiency? I just want to make a research regarding this matter for my upcoming report about information technology facts.
Chloe Chylly.
puneet7
A pic compiler (or any compiler) is a program that translates one computer program into another. Source code written in a high level language is translated into machine code that the microcontroller understands. This simplifies the task since we do not have to write assembler – we are only concentrating on the high level language. The main advantages of using the PIC Compiler is:
The Compiler language lets's you:
Code applications more quickly – less lines of code than assembler.
Write programs that are easier to understand.
Use ready made libraries – you don't need to write as much code.
Concentrate on the task – it manages low level hardware details.
Use the same source code for different target micros.
Work only in the high level language – no need for assembler.
Read the code easily (see layout of the example above).
Program different microcontrollers in the same family e.g. PIC.
Learn a standard language such as C to use in a profession.
mvirk35
Its much easier working with a high level language because it uses words that are recognized by humans
This results in a program that is easily to understand. With the help of this compiler you can visually described the program flow using tabs and spaces.
