Hi guys,
I want to know why my galaxy S3 is not detecting any WiFi networks. Actually what happened is my galaxy S3 smartphone got in touch with wall little hard and it was switched off then I switched it on. Since then I can notice that WiFi is not working in it. Please tell me how to fix it.
Why Wifi is nnot working in my Galaxy S3?
If you want to solve this trouble you should follow the steps given below :
Step 1 : Firstly, you should search for settings option.
Step 2 : Secondly, you should go to Connections option.
Step 3 : Thirdly, search and select more network option.
Step 4 : Then select mobile network option and select network mode.
Step 5 : In step five you should select network operators.
Step 6 : Finally, select automatically preferred network. In this process, you can resolve the problem.
Moreen Jamnelly.
