Why would you use MKVtools to merge mp4 files on Mac computers?
Why would you use MKVtools 3 to merge mp4 files on mac computers? Wouldn't you use something like iSkysoft Video Editor for Mac which supports editing of videos not just joining of two videos. What else can you suggest for video editing on the Macintosh?
Best Answer by Huffman Serafin
Answered By 0 points N/A #171331
Hi Joseph G Aguilar,
I am always recommending the software Adobe After Effects for video editing because it is a great software, developed by adobe company and is an advance editing software in which you can actually imitate the star wars scene using with only a boy who uses stick as his sword for a video clip, other than that, it can also edit some entry videos that is fascinating
Answered By 0 points N/A #171332
Hi Joseph,
                You may want to check Jahshaka or known as CineFX this can work on all three platforms Mac, Linux, and Windows. Having said that it can run in cross platform so no need to worry about compatibility. It is often compared to Adobe After effects, once you have seen this program you may get anticipated with their new updates.
