Wi-Fi router password forgot retrieve
I am using a DB 108-WL ADSL Modem with WiFi router and I forgot the password, Is there any way I retrieve it?
Hello Jasmine Mendez,
   Well, there is probably no way to retrieve that forgot password of yours. Although you cannot retrieve the password, you can still access your wireless router's connection. Instead of retrieving the forgotten password, why don't you just restore your wireless router to its default factory settings. That way you can access your wireless router's options through the default account name and password of your wireless router. You see, each manufacturer has a default account name and password which is subject for the user's change. Now, that you cannot access your wireless router's settings, then just reset your wireless router. To reset, your router to its default factory settings, then refer to your manual, or just simply visit your manufacturer's settings. In my case, resetting my router is done through pressing a button in the router for 10 seconds to 1 minute. After that, configure the options once again as you please.Hope this helps.
>>Mathew Joni<<
