Wifi Direct on Acer Aspire
Hi
Normally the producer provide driver CD with the Laptop which include all the driver software for the laptop. So if you have one install wifi drivers from CD.
If you don’t have CD go to the acer web site and download driver. Use link below to download. Then you can install the wifi drivers.
Generally, a Wi-Fi is not like an application that needs to be installed on a computer or in your case, your laptop. All laptops are capable of using a Wi-Fi connection because this feature is already integrated within the machine. To be able to establish a Wi-Fi connection or to connect to a Wi-Fi network or hotspot, you need to check if the Wi-Fi drivers were already installed on your machine.
Check with the documentation of your laptop for your reference on which driver to install for its Wi-Fi device. When this is already installed, the next thing to do is to connect to a Wi-Fi hotspot to start a Wi-Fi connection. Or you can ask your ISP on how to create your own Wi-Fi hotspot because this is usually on a subscription basis.
You can search over the network for the required driver for wifi in your laptop. The best way will be to search the Acer site and after entering the model there you will be able to download all drivers for that machine.
Smith Thompson
