Crewe Bob 30 points N/APosted on - 12/18/2013
Hi there,
I have Sony Xperia Z which I usually connect over WiFi, but I have realized that when am on a call, the WiFi connection temporarily disconnects, which interrupts downloads which cannot be resumed, what could be the problem with my WiFi connection? How can I make the connection to be continued during a call?
Many complain against Xperia Z for weak Wi-Fi signal. Some people have had trouble connecting to network and some faced signal drop frequently. For some cases problem caused when Bluetooth and Wi-Fi are. Another possibility is power-saving Stamina Mode, stops auto sync and can cut. Display always goes off during a call once proximity sensor analyzes respective ear/touch.
1. So, first check strength of wifi signal, if this is not ok, then don’t perform rest of the steps
There are thousands of good free wifi strength scanner apps in google play
I don’t think that’s a problem because it is normal. Just like with a computer, when you are downloading a file and at the same time you are watching a video on YouTube, your download gets very slow because you are using the same internet connection for the download and video streaming.
Though the download doesn’t get interrupted in the computer but the downloading process tends to be extremely slow. In your case since you are using a Smartphone, the download can get interrupted if your call is using the internet.
If you receive the call using an app like Skype or WhatsApp which uses the internet, any file that is currently being downloaded will be interrupted which might lead to stopping of the download. If you don’t want this to happen, avoid receiving calls when you are downloading on your phone. Anyway, here are the specs for your phone.
The Sony Xperia Z is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public on January 2013 and released on February 2013 measuring 139 x 71 x 7.9 millimeters and weighing 146 grams. It uses micro-SIM card with front and back made of glass and the frame is made of plastic.
Sony Xperia Z
It is IP57 certified (dust and water resistant up to one meter for 30 minutes). It has TFT capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution. It supports multi-touch up to ten fingers (10) protected by shatter proof glass.
It runs on Android 4.1.2 Jelly Bean upgradable to Android 5.1.1 Lollipop powered by Qualcomm APQ8064 Snapdragon S4 Pro chipset, 1.5 GHz Quad-Core Krait processor, and Adreno 320 GPU. It supports microSD expandable up to 64 GB. It runs on 2 GB RAM with 16 GB internal storage.
The primary camera supports 13.1 megapixels with f/2.4, LED flash, and autofocus featuring geo-tagging, face detection, HDR, sweep panorama, and touch focus. It supports 1080p video recording at 30 fps with HDR support. The secondary camera supports 2.2 megapixels and supports 1080p video recording at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP support; GPS with A-GPS and GLONASS support; NFC; stereo FM radio with RDS support; and microUSB 2.0 with MHL TV-out and USB Host support. It has built-in accelerometer, gyro, proximity, and compass sensors. The preinstalled web browser supports HTML5.
It runs on non-removable Li-Ion 2330 mAh battery with standby time up to 550 hours on 2G and 530 hours on 3G. Talk time is up to 11 hours on 2G and 14 hours on 3G. It is available in purple, black, and white colors.
1....
