I have an Iphone 4s with iOS 5. I'm looking for an app to install on my iphone that can detect signal strength and dead spots. I also need the SSID encryption and channel frequency. Is wifi strength detector accurate?
Is Wifi strength detector accurate for iPhone 4s?
I will provides you couple of links, But that letter, Now these software are available on ITunes and other third party tool as well. The software will provide details such asSSID, BSSID,There are few WIFI speed enhancing software and information are there as well. Now here is the link, it will provides you the details and how to download and implement.
Source site 1
Source site 2
Thanks
Hello Wayyne White,
You can manually increase your WiFi speed. You can follow the steps below to increase your WiFi speed.
1. Go to settings.
2. Then, enter the WiFi menu.
3. Check the blue “network connecting” icon.
4. Scroll to the bottom.
5. Make the HTTP proxy “auto”.
6. Leave the URL blank.
7. Now, save it.
This can increase your WiFi speed. You can also download iTunes 10 10 to detect signal strength and dead spots.
Yes, it accurately detects WiFi strength.
