Wii Says Error Has Occurred, How To Fix It?
My Wii console is not working properly. I don’t know whether the problem is with the disc or the console. How to fix the error when Wii says error has occurred?
One of the following methods can help-
1 – Clean the disc. Sometimes dirt accumulates on your disc, and the console is unable to read it. So clean the disc and insert it again.
2 – Insert some other disc in your console. If the problem occurs, then something is wrong with your console, and you need to contact the support team for repair.
3 – Again, insert your disc in some other console. If it works fine, then you need to get your console repaired. If it does not work, you need to get your disk repaired.
