jabez zion
10 points
Posted on - 10/28/2012
Hello friends
I am using Mac OS- snow leopard on my machine, and I have recently installed the Wiiflash server.
It was installed successfully but when I launch it, it gives me an error.
The screenshot of the error is attached below:
The error says:
Cannot launch Java application
Uncaught exception in main method:
java.lang.llegalStateException: Bluetooth failed to initialize. There is probably a problem with your local Bluetooth API.
Is this server not supported by Mac OS or there might be another reason for that? Please let me know if anyone has a solution to my problem.
Waiting for your replies.
Regards.
WiiFlash Server on MacOS – Snow Leopard
Good day Jabez,
I think this would help you solve the problem or atleast help you with your problem:
1. Right click on the .app file
2. Go to "get info"
3. There should be an option to run in 32 bit more.
4 Then check it.
Hope it helps. thank you and god bless
zelnluv
Good Day,
Aside from what I previously stated, You can do one or more of the following below:
a. Running the Program on the 32-bit mode, (if your 64-bit and vice versa.)
b. Open your Java preferences and switch priorities.
c. Uninstall and reinstall program, make sure the first run of the program is already at 32-bit.
d. If you have a little programming background, You can download the Eclipse Classic (32-bit ed.)/ or other Java Development Tool or IDE, import the WiiFlash source code as a project, compile and run, import as a JAR file, and replace the one you made with the one on your .app folder.
e. Or if your a little risky, you can visit (http://aross.io/play/wiiflash-server/), which has there own version of the WiiFlash Server with there own touch up for the error.
Hope this Helps!
GoodLuck on your gaming.;)
