Will bcd fix Windows XP gui disk structures?
Asked By 110 points N/A Posted on -
Will bcd fix windows xp gui disk structures? How many minutes does it usually take to do this process? There are some parts on the gui that won’t load or display properly. I’m trying out windows editor that is more user-friendly and easy to navigate so my system will not hang up anymore.
Answered By 55 points N/A #144616
Hello David Parfit,
           If you want to edit your windows then you can use BCD visual to change the look. It can also help you in making a GUI for your disk too. But if you just want to change the outlook then you can use any of the theme so that you can get your desired result. You can get many themes from the windows official website that you can download and you can install them easily and can get your desired result.
