Will driver print artist 8 work on windows 7?
Hi everyone,
I am using driver print artist 8 for creating greeting cards and family calendar in XP.
Now I want to install windows 7 on my PC.
Will it support on windows 7,
Please answer me.
Hi everyone,
Please answer me.
Hello, Margaret!
I have known to your post that you are using driver print artist 8 for creating greeting cards and family calendar. After all you have to be careful that your system is windows XP.
You are interested to use it in windows 7. Well, you certainly can use it but you have to update it and install additional requirement.
After all you can search for Google for getting additional solution.
Best of luck!
If you want to install Print Artist 8 on Windows 7, I don’t think it will install because the operating system is not supported. Print Artist 8 is way too old for Microsoft Windows 7 but you can try starting it in compatibility mode. Print Artist 8 supports Windows 95 and Windows 98. If you have Windows 7, see if you can run the installer and install the program.
If the installer doesn’t start or is giving an error, try launching the installer in compatibility mode. Right-click the setup.exe file for Print Artist 8 and select “Properties”. In the properties dialog, go to “Compatibility” tab. Under “Compatibility mode” section, check “Run this program in compatibility mode for” then select either “Windows 95” or “Windows 98” from the dropdown list.
Click “OK” then start the installer. If this doesn’t work, another option is to install the program in a virtual machine. You can use VirtualBox to create your virtual machine. It supports Windows, OS X, Linux, and Solaris hosts.
