Will FoxPro for UNIX still available in market?
Hi Friends,
My client who is still using FoxPro (DOS version) and they are not precisely pleased with the existing support group of the company. The situation is in a nutshell what my client is currently running SBS 2003. This is the only thing which he uses it for his FoxPro.
My requests are:
Will FoxPro for UNIX still available in market? I know it's not kept as such, but can it still get it?
Does (or did) it ran on Solaris?
Is there is any way to migrate or restore the backups from the DOS version to UNIX version and make it online?
Does anyone try Dosbox on WABI or with wine?
Thank you.
Best Answer by Zender Lowry
Answered By 0 points N/A #198371
Yes you can easily buy FoxPro UNIX from online. The FoxPro runs on Sun Solaris operating system.
You can migrate or restore the backups from the DOS version to UNIX version and make it online.
Many specialist try and success Dos box on WABI.
Thanks for your question and information.
Answered By 0 points N/A #198373
Yes, the Foxpro for Unix is available and you can free download the software from web. The FoxPro is also supported Windows XP, Vista, Windows 7 also Solaris.
You can easily migrate the backups from the DOS version to UNIX version. All the works will be supported platform of online. Many people are use Dosbox on WABI.
Answered By 20 points N/A #139905
All of your suggestions were helpful and essential too. Thanks for your vital messages. Zender Lowry, I was astonished with your solution. You explained all the answers to my question so nicely. I learned about all my requests from reading your comment. Thank you my friend for sharing your knowledge with me.
