Hello, I am trying to find a way to improve the performance of my notebook. I have an HP Core 2Duo T5670, 1,8 GHz, 2GB RAM. I used to have win xp,but now I have upgraded to win 7 and it works better. Searching the internet, I found a diagnostic tool, HP library and tape tools, and I want to know if it is good for my notebook. Thank you.
Will HP Library and Tape Tools increase my notebook performance?
Indeed, It is very good for your notebook.It not only provides improved performance but also adds compatibility and fixes hardware bugs.It has an integrated customer support system which has a fast diagnostic tool, to check for the most commonly occurring problems before you submit a ticket.
I would like to suggest you to opt for upgrading your notebook. The least and the most affordable option would be to upgrade your RAM for better performance.
