Will Land 64 bit run on Windows 7?
Good day fellow Techyv members.  I have a question regarding Land 64 bit.  I plan on using Land Desktop 2004 for road planning.  Will it be able to run on a Windows 7 64 bit system?  Any help would be much appreciated.  Thanks in advance.
Answered By 5 points N/A #177467
Hi Emileekeila,
Definitely your Land 64 bit software will run on your Windows 7. The reason is that your version is compatible with Windows 7 therefore it will function as it should be Having a 64 bit version will be well-suited in a 64 bit operating system. Such an example; if you run a 64 bit OS and you have the installer working in 32 bits, it won't work accurately. In your case, you have the correct software version therefore you shouldn't have any reason to have an issue installing this on your machine. I would recommend to update your drivers and hardware upon installing any kind of software, that would really help.
Hope this clarifies.
