Will MS surface tablet be able to run MS computer programs
I know Microsoft is producing its own tablet. Will this table be able to run Microsoft computer programs or just downloadable apps.Â
Dear Margaret,
That's the best thing about the Surface. There will a version, simply called PRO, that will be able to run the FULL version of Windows 8. That means that anything you currently are running on your PC, you'll be able to run on the tablet (assuming Windows 8 compatibility for the above mentioned applications).
However this is only for the PRO version. The Surface will come out in two flavors: RT and PRO. The RT version will run a more stripped down version of the Windows 8 OS and will have less powerful hardware. This feature won't be there for the RT version.
So there's nothing more to say, when the PRO version comes out, reach out and grab it, if this is what you're looking for in a tablet, 100% compatibility between PC and tablet.
I hope this helps.
Dear User,
There are three Main things you will get From MS surface.
They are:
1. Trade on the laptop for the Tablet.
2. Better Support, and more Applications.
And I will support almost everything. Within the windows 8 app market.
3. A Simple Transition.
My opinion is I wouldn’t have missed this for the world.
Thank you.
