I have various Apple products like Iphone and Ipod Nano. What I need is a portable speaker that I can bring anywhere. Will this fit my need for the speaker? Is the quality sound good? What about the price is this affordable?Â
Will this NuForce Cube speaker deliver good sound quality?
      Yes! NuForce Cube speaker is good one. Its sounds cool. If you want to have a good and cool sounds wherever you want to go this is the best to buy. The quality of the sounds that you are looking for like the base, treble and mid mixture is so good. It cost $120, expensive but fit to the quality that you are looking for.  This speaker can also connect into a computer via USB.  It is small but sound so good. If you are using cheap players and need better sounds, this will be fit. So for you to know more about it, buy it. J
