Will there be a new accessory for xbox360?
I like games like of the jackie chan featured using gadgets to do bowling or tennis using a bat or wrist cover. Will there be something new for xbox using own body movements and voice to play without additional gadgets?
Best Answer by Dev George
Answered By 0 points N/A #133759
Yes you can use a Kinect camera with your Xbox 360. Kinect is a motion that detects the camera and will allow you to use it using your body movements. It utilized a special tool that will trace your body movements and decode the movements to the game. So you won't be needing any joystick/controller to play the Xbox 360. You can also use voice commands when playing on it since there is a voice recognition feature in it. So you just don't play games with Kinect but you can also use the motion controls just by making commands and say "Xbox" and then "Kinect" to launch the voice commands.
Video chat feature is also available on Xbox Live where you can move around and chat at the same time.
You can purchase Kinect for $149.99 in U.S with additional copy of Kinect adventures games on it. If you will buy an Xbox 360, you can get it 4GB Xbox 360 S with Kinect for $300 and a 250GB Xbox 360 S with Kinect for $400.
Xbox 360 S has a built-in power supply port that can connect to Kinect without having to use any cables. Older model of Xbox 360 consists of all the required cables on the package to connect it with Kinect. You just need to plug Kinect on A/C adapter and connect the Xbox 360 via USB port.
If you will play 6-8 feet away from the Xbox sensor, it will work better with Kinect rather than playing closer than it. So it is advisable to buy a Kinect when you have a large space on your room.
Answered By 0 points N/A #133760
xbox360+kinect is now possible. just use your body as a controller, when playing video games…i think thats more fun.
and searching for movie using only your voice, it's possible with kinect. You are the controller, simply step in front of the sensor and kinect will recognize you….it's the future of gaming so go check it out..
