Will there be a Sketchup app for iPad
I have always used Google Sketchup for 3D designing.  I was wondering if there would be a Sketchup app for iPad? It will be very useful especially for presentations.  I have the 1st Generation 64 GB iPad with 1 GHz Apple A4 processor and PowerVR SGX535 GPU.
Answered By 0 points N/A #182941
Hi parker,
Unfortunately there is no official Google Sketchup for 3D designing especially for iPad, it's not possible to design using this software on Apple products but to make it easier for you there is some apps that make viewing 3D Sketchup files possible on the iPad or iPhone such as SightSpace 3D.
Douglas
Answered By 590495 points N/A #310372
If you are looking for an iOS version of SketchUp, I’m not sure if you can find one but a viewer application is available on the Apple App Store. If you want to try it, go to SketchUp Viewer. The app is available for iPhone and iPad devices. SketchUp Viewer supports iOS 8.0 and works on iPhone, iPad, and iPod touch.
Unfortunately, SketchUp Viewer is not free. It costs $9.99 and rated 4+. With SketchUp Viewer, you can bring 3D models to reality by allowing you to open and view SketchUp models on your iPhone and iPad any time. The app is recommended for devices with at least 1 GB RAM. With the latest SketchUp Viewer 3.2.3 update, it adds support for the SketchUp 2018 file format.
