Will Window 8 Run on Existing PCs?
Touch input is great,but what about the billions of non touch PC's out there.Will windows 8's touch-centric interface work on PC's?
Yes! But still depends on the hardware specs of your computer. You need to have at least 1 GHz or faster processor, 1 GB RAM for (32-bit) or 2 GB RAM for (64-bit), 16GB hard disk space for (32-bit) or 20 GB for (64-bit).
It still can work on non touch PC's computer but if you will use touch screen computer it much better and you will appreciate the graphics of Windows 8. If you will use non touch, you will not notice or appreciate the functionality of some graphic features of it. I tried windows 8 on mobile, and it was great.Â
