Will windows simultaneously work with Apple OSX ?
I recently got a MacBook Pro but there works of mine that wont properly display in safari.
It will only work on Internet Explorer.
Is there a way to have Internet Explorer also in MacBook?
How will be the installation?
Answered By 0 points N/A #129956
You can use Internet Explorer on Mac also. But there you need to install it in your system.
Download the IE from the link
Alternatively you can even look at the Link  which is a separate site from Microsoft only for Mac users where you can find those applications which can be used in Mac OS.
There are different applications like word, Excel, Web-Apps, Lync which can be installed in Mac also. just download the necessary things and install those in your system which ever is required for you.
Make sure you read the instructions properly there are bugs in IE also.
