I found Add Remove Program Cleaner freeware online and I’d like to check it you have tried using this. Will this work for a clean adobe writer uninstallation? There are still components that are not allowing me to reinstall some other adobe software. Let me know if this is a good idea. Thanks a lot!
Will this work for a clean Adobe writer uninstallation?
Hi Daniel,
The cleaner ware should work, I have tried some cleaner softwares and they work with most programs, however they fail to complete uninstall others. I advise you to remove the remaining components via the registry. Go to start, then RUN and type REGEDIT and enter. Then search for the Adobe software you want to uninstall by typing it's name and delete all components associated with the software.
After you have cleaned the registry then do a fresh installation. This should work.
Cheers.
Hi Daniel,
I have used tons of add remove cleaner free ware’s and this is by far the best one yet:
here is the link.
A very simple way to solve your problem is just format the folder in which you installed adobe writer, disable windows updates for a while; restart your PC and problem permanently solved.
