Will you actually be able to fax directly from Word 2013
When Microsoft Office 2013 comes out will you actually be able to fax from Word and If so can you fax from the other programs as well or will you have to import the other objects into word.
Hello Ms. Roth
The based on my research for you the answer is yes. You can directly fax using Microsoft office 2013, but you need to install a program to make it appear in the left pane of office 2013. The program name is Efax this is a cloud-based with an Efax subscription you can send and receive faxes via email or the web from smart phones, tablet or any internet connected devices.
The E fax software automatically integrates itself into office 2013 upon installation.
For more reading please refer to this page.
Hope this helps you.
Have a good day!
Dear User,
Yes you can send faxes using office 2013, it uses and app called eFax. And this is the first online Fax app introduced in to Office package.
Also this technology is cloud based. You can send and receive faxes via email or the web. To or from your smart phones, tablets or virtually anything that connects with the internet.
But this is however said to be an integrated app in office 2013. Directly into word 2013. It appears as an option in the task pane. One the right side of the window
But no way of knowing yet, that would it be able to work with any other applications. But my guess is
Yes it would work with other office based applications.
Thank you
