Will you please give link of free software for decoding dvd?
Hey guys why the Nero burning rom can't burn the movies that I have downloaded earlier? It seems I need some software for decoding dvd?
Will you please help me by giving a good source of softwares that can be used for decoding dvd?
Best Answer by Thathri elsebet.
Answered By 0 points N/A #133882
You are having a problem regarding nero burning rom as it cannot burn the movies that you have downloaded earlier. Yes, you need some software for decoding the same.
You can visit the site http://dvd.brothersoft.com/dvd-rom-decoder.html for downloading the software. This is a good source of the said software for decoding dvd.
From here you can also get necessary help regarding decoding.  It will help you to change the format of your downloaded movies as compatible with nero burning rom.
With assistance of this software you can use nero burning rom to burn the movies. I think it will be ok.
I hope you understand it.
Answered By 5 points N/A #133883
Hi there,
If you just want to burn or play DVD format on your pc then I will suggest you download VLC media player which is a highly portable multimedia player for various audio and video formats (MPEG-1, MPEG-2, MPEG-4, DivX, mp3, ogg, …) as well as DVDs, VCDs, and various streaming protocols.
If you really want a Decoder Software then you have number of choices, either you can buy or you can download free decoders.
Try this link “http://dvd-decoder.software.informer.com/ “
It contains a free DVD decoder pack for Windows
Try this link also “http://ccm.net/download/download-972-dvd-decoder-pack “
Another complete version of decoder pack
“http://dvd.brothersoft.com/dvd-decoder.html “
Another decoder for you!
Hope it works for you!!
Answered By 590495 points N/A #344895
If you use Nero and you encounter this error, you are probably using a free trial or a demo version. Try using a different burning software. First burning software you can try is ImgBurn. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including earlier operating systems like Windows 95.
It allows you to burn CDs, DVDs, HD DVDs, and Blu-rays. It offers several modes you can use:
  • Read – this allows you to open an image file like ISO.
  • Build – this allows you to create a disc image or create a disc image from the files on your hard drive.
  • Write – this allows you to burn a disc image to a disc like burn an ISO image to a CD or DVD.
  • Verify – this allows you to check if a disc is one hundred percent (100%) readable.
  • Discovery – this allows you to test your drive and check the quality of the burns your drive is producing. This is used with DVDINFOPro.
Second burning software you can try is DAEMON Tools Lite. The latest version at the moment is DAEMON Tools Lite 10.
