Willing To Buy Hp Printer Ink 27 28 At A Steal!
Looking for a new cartridge 27 28 for my hp printer. Where can I buy the same at a steal or really cheap? I have heard online shopping is more beneficial for the same. Any suggestions?
Answered By 0 points N/A #297092
The price entirely depends upon the kind of cartridge you want to buy. If you wish to buy a simple black one then it will not cost you more than a couple hundreds but if you want to buy a coloured cartridge, it may cost you triple the amount than the simple black one. Further, whether you want to buy from the authentic store or from any other seller, that will also determine the rate. Here are some I found online.
