James Craig
40 points
Posted on - 06/27/2012
Wimm One is a smart watch that can run free Android applications. It can be connected to smartphones via Bluetooth. What smartphone is the best pair to the Wimm One watch and what capabilities will I be able to maximize?
Wimm One smart watch for what Smartphone?
Hi James,
Actually it doesn’t matter what Android smartphone you use with WIMM Onewatch but it’s always good to have same Android version on both WIMM Onewatch and your Android Smart phone. Means if your WIMM Onewatch is running on Android 2.1 use a smartphone also with Android 2.1. But smart phone with latest Android also work pretty fine.
It’s good to team up WIMM Onewatch with Galaxy Nexus because Galaxy Nexus’s vibrator is pretty low. It will give you the advantage. But that’s the weak point in Galaxy Nexus not in WIMM One watch. It’s better to use with latest Galaxy S3, else if you want a Galaxy Nexus with weak vibrating.
