Myalrani
Posted on - 11/30/2012
I heard about new software Win Speed up 2 8 by Script Soft although I am using Win speedup 2.7. It work perfectly but I decide to experience new version of this serial. If anyone is using this application kindly tell me what are the new Functions & Features of this application along with this guide me, Should I change Win Speed up 2. 7 or keep using it. Thanks
Is Win Speed Up 2.8 more useful than Win Speed Up 2.7?
There is not many changes in version 2.8 from 2.7
-Biggest change is added support for Windows Vista but i guess that doesn't means a lot for you.
-They added file exception list for "Clean-up drive"
-Internet Tuning improved
-A lot of small errors were fixed,it will run more stable now
You should upgrade to version 2.8 mainly because it will run more stable.
Script Soft released version 2.9 which is newer and better.
-Support for 4 GB RAM or more
-More sizes for L2 cache
-Shows size of deleted temp files
-And fixed some errors
The best thing you can do is to upgrade directly to version 2.9
The special features of the latest version of Win Speed up are as follows:
>>Program starts faster.
>>Accelerates system start up.
>>More lighter than the previous version.
>>Cleanup hard drives and RAM.
>>Edit start menu, repair windows, tune start files.
>>Manages fonts.
I suggest installing the latest version of Win Speed Up to ensure the best performance. It can be available for download in the official website.
Thanks and regards,
Skarbos Jay.
