STOP Error on installing Windows XP
I get this after installing XP:
This error occurs when a driver uses an incorrect memory address. Other reasons that could be responsible could be an incompatible device driver, hardware problems or incompatible software.
Hi good day,
You’ve got the same error during installing the of operating system, the most cases of this kind of error are missing or corrupt system files,incompatible software,incompatible device driver and corrupt operating system. The solution of this kind of error is windows recovery console and repair corrupt data structures. Or make a new installation of Windows system again.
Thank you, hope it helps.
Regards;
henjobeder
Cause:
Reinstall the device drivers.
Restore the Windows operating system.
Use the Windows Recovery Console and repair corrupted data structures.
Format the hard drive and reinstall the operating system Windows XP.
You have to format the hard drive as a last resort. It deletes all files on the hard drive and cause serious problems.
In such cases try: Stellar Phoenix Windows Data Recovery.
Stellar Phoenix Windows Data Recovery is a powerful, easy to use File Recovery application that recovers files from lost, deleted, damaged or formatted ; is for fat16, FAT32, NTFS, WINDOWS 7, WINDOWS VISTA, WINDOWS XP.
These tools file recovery provides recovery through an interactive user interface.
