Win xp – parallel desktop- unable to allocate virtual Machine memory
Hi guys,
I have windows XP installed on my system with 2.4 GHz intel core 2 duo and 4 GB ram. I am facing some issues with parallels desktop.
I decided to delete the virtual machine and reinstall the windows. I did this, but it did not work.
Then I reinstalled parallels and restarted my system but it resulted in the following error:
The message states:
Winxp – parallel desktop
Unable to allocate virtual machine memory!
This error may occur mostly if there is no enough free disk space available on the physical disk to allocate virtual machine paging file. Try to clean up the physical disk (remove unnecessary files). If it doesn't help, try to re-install Parallels Desktop.
OK
Can anyone please shed some light on how to resolve the issue?
Any help in this regard will be highly appreciated.
Thanks a lot.
Regards.
