Is win32 tour application will work on windows 2003?
My friend has a basic win32 guided tour application which is working fine with windows XP. He told me that he already tried using it using windows 2003. I just want to know if it is not possible to run win 32 application on windows 2003 even with complete keygen. Our school still have computers with old windows systems just want to make sure once we present our work it will definitely work smoothly.
Answered By 10 points N/A #154987
Hallo Toni,
I guess it is possible to run the win32 guided tour application but then you will need to ensure that you do either of the following when installing the application.
You can either:
  • Redistribute the application by making a release build.
  • Or you can choose to redistribute it by creating an installer package that includes visual C++ dll files.
Note that there may be bugs that may develop in the process, but there is a way to debug the release-build applications in the systems that are not licensed for visual studio applications.
Hope this helps.
Carl
