Preston
Posted on - 09/09/2011
When I try to watch some videos with Winamp, it throws me an error below.
Some videos work, but lagging badly. I tried to resolve the problem by reinstalling Winamp, but the issue remains.
Operating system windows XP.
Waiting for a solution!
winamp.exe – Application Error
The exception unknown software exception (0x0eedfade) occurred in the application at location 0x7c812a5b.
Winamp application error when trying to watch a video
It really happens to Winamp when playing videos even if the video format is supported. Winamp is an audio media player and it is still being improved on playing video files so don't expect too much from this program.
And maybe that version of Winamp you have is one of the earlier versions. I have here a Winamp v. 5.58. Its ability to play videos is already good. Try searching the web for a free download on this version.
So, even if you uninstall and reinstall it a hundred times just to try and hoping to make it work, you will be stuck there forever.
Or just use other programs to play that video of yours.
muchacho
Hi
If you have all the codecs installed then you probably have a bug in your operating computer.
Do a thorough check for malware, following all of the steps at one of these web pages.
Help with malware:
All MS-MVP Sites.
Unexplained computer behavior may be caused by deceptive software.
